cactus jack
- May 26, 2009
- 1
hey folks,
VERY new to boating but have read MANY MANY forums esp on here.
here is what my wife and i are looking at.
a gentleman is wanting to trade my Fully running MC for a boat. heres some of the things on the boat, and YES i went and test drove the boat, however heres what ive found.
its a 20.25 ft. 1987 GALAXY Admiral 212 CC.
it DOES have a (dreaded- Mercruiser 470-165 hp. however rebuild...) 4cyl motor mounted up to an Alpha one drive. Hull is in Decent shape, i believe the floor has been replaced in the boat, Solid no soft spots, and ran quite well in water. (30Mph) and kept at 164degrees. HOWEVER... it DOES have the dreaded Coolant Leak from the Camshaft. not terribly bad. HOWEVER.. and a big however , i called him today and mentioned that the motor is making me say NO way... he claims he has a friend with a VERY Strong 1992 Mercruiser 3.0. he is willing to drop in and claims will bolt up with no problems. the shifter/throttle seems a little sloppy, as it kinda dies out when you shift into forward, however (can be minor adjustment at the linkage, or new cable i learned) the trailer is in good shape, and one that is extendable.
needs Bimini top, and cover, looks like its sat out a little bit from what ill have to repair(the wood under the seats what youd staple the seating vinyl to) cuddy is in decent shape, however no cushions, but it would primarily be for the wife and kiddo to get out of the sun... Needs Bilge pump as last one is bad, (20-50 @walmart. EASY) but did not take on a great deal of water.
the gentleman seems honest and sincere, and really has no need for 2 boats, due to having a 26ft boat already.
i know not having photos is a bit rough for all to assume. PLEASE PIGEON HOLE THE CRAP OUT OF THIS and PLEASE TELL ME WHAT YOU ALL THINK. good move? bad move? a money pit?
PLEASE HELP!!!
thanks all!
ryan
PLEASE HELP!!!
thanks all!
ryan
