Greetings. I just picked up an 18 HP Johnson dated 1959 that ran strong the first time out. Amazingly I am the 2nd owner of this motor. It ran great like I said however the red (slow) adjustment seems to have stripped out and loosened up counterclockwise 3 plus revolutions. I keep the white (ast) dial set between 4 and 5. I was only able to obtain enough rpm's to keep the motor barely running. I returned home and saw that that had loosened up and I tightened it up and set it back close to 3 on dial. The dial seems to be stripped now and wont hold tight. Is there something I can do to fix this setting? Is the carb shot now because of this? First time boat owner so any help or guidance would be greatly appreciated. Does anyone know of any good mechanics that can fix this up here in Wisconsin if it gets to that point? Thanks in advance!
