Trouble with Johnson Seahorse 4 HP Model J4BRCIC Serial No. BOO6466 (1981)
debnjit
I am having trouble with this engine. It stops after about 8 mins. It starts on the second pull every time, from cold and after it has stopped. I have set the Lean/Rich lever but this does not do much.
The engine runs at much less revs. Also when opening the throttle it will some times cut out instead of running at higher revs. I've run the engine with the fuel cap off incase it was causing a vacuum in the petrol tank but this didn't make any difference.
So I am now stuck. Has anyone got any ideas please?
Any suggestions would be welcome
Many thanks.
David Smith care of Debnjit (daughter)
