I have a honda 5 hp 1997 that's running rough at idle and mid range.
I changed the oil in the engine, lower unit, put in a new spark plug and fresh gas. I also checked the compression at wot (throttle rod disconnected and pulled) I raised quickly in a couple of pulls to 150 psi.
After running it in the tank for 10 min at low speed the engine still ran rough missing at idle and mid range. I checked the spark plug and it was very dark so it seems to run too rich. I pulled the carb apart it looked clean but I noticed the idle screw was a 3 3/4 turn from bottom. What is the base setting for this screw? 1 1/2 turn?
Is there risk of dommage to the plastic parts of the carb (choke mechanism) if I let it soak in solvent? which solvent do you recommend?
Should I check the valve lash ? what is the spec and how I sould adjust it ?
thanks
Michel
thanks
Michel
