Not to sure what is going on, but was told to look at the electrical. So some basic information to start off with;
1985 Evenrude 90hp V4 VRO (VRO removed and use premix gas (50:1))
This winter I rebuilt both carburetors, new fuel filter, new gas line, new started gear, and replaced all the spark plugs. I was having this problem last year. The motor is cold hearted but will start up fine. This weekend I was out running at WOT for a while and the motor just stopped. It would not start right back up. But after 45 min or so I tried it again and it fired right up and ran like normal. I moved to another fishing spot and tried to for 15 min and thought I would try some where else. Again it would not start. So I fished the hole a little longer and tried the motor again. It started right up?!? It seems like I almost need to wait 45 min after each time I run the motor to get it going again or it won?t want to run.
What could this be
Thank you for your time and help.
What could this be
