Hi everyone, IM brand new here ( and to fixing boats) but this looks like the place to come. I have a 1989 21 ft aquasport cuddy cabin walk around. I bought it 2 years ago and have only used it 6 times so far. Im getting cracks in my gel coat. After looking in the videos it seems there are 2 type gel coat repair types, polyester and epoxy. Which is the superior of these two? Also I keep reading that cracks in the gel coat on the transom can be transom rot. I have crack on each side of my transom in the gel coat. It is right in the corners where the outboard cutaway hits the main part of the transom. they are just hairlines and go only across the top 2" of the inside corners. I have a 2 stroke 225 hp evenrude outboard and have gone as fast as 50+ MPH at about 4500 rpm.
This spring when I came out to check out the boat I did find a soft spot on the deck. ITs about 8" in diameter. It is adjacent to a waterproof access door. IT seems like water ran under the access door edge and rotted out the wood. THe good part is that it is in the middle of a 6' X 4' screwed in panel that comprises most of the floor. WOuld it be better to remove the entiire panel and make a new one, or try to repair the soft spot in the old one?
One more question before I go, should I pull all the screws on the boat and reseal them with some kind of sealant to keep water from entering the wood areas? If so, what kind?
Thanks for any help that you all can supply.
