1989 Mariner 75hp continuous alarm
Hello, i have browsed around at previous topics on here but i still seem stumped, hopfully someone will be able to point me in the right direction...I have a 89 merc 75hp mariner on a center console boston whaler montauk. When i put the key in the ignition and turn to "on" the alarm starts, I am pretty sure this is normal? then once i start the engine the alarm turns off. After running the motor for about 10 -15 minutes the alarm starts up a loud continuous beeeeeeeeeeeeep and i loose my RPM guage completely. If i turn the ignition key slightly to the off position i can tweek it enough so that the alarm stops, however i still loose my RPM indicator. I recently had the lower leg serviced and the impellar and leg sensor was replaced. I have seen on here that continuous alarms indicate an overheat, i can rest my hand on the motor for more than 3 seconds and the water isnt overly warm.
Also, When i first start the motor, i can wiggle the key a bit and this will also start the loud continuous beep, The sound then begins to get very patchy and and not a sharp continous beep.
I have read on previous posts a similar case, The person found that it was a oil warning module. Is there any way i can test this?
If anyone has any help that would be great. I am pretty hands on with mechanical and electrical, i just need a starting point.
thanks,
kyle
