MerCruiser 120 No spark at coil
inkdragon11
I have a 80 or so MerCruiser 120. Ran good all last year. Winterized it and tried to start it. Turned over but didn't fire. No spark at coil. So I replaced coil, (rotor and cap looked worn so I replaced at same time). Still no spark at coil. Where do I go from here.
gshldon
Re: MerCruiser 120 No spark at coil
did you check the nuetral switch, and also make sure all grounds are attached, also check to make sure your wires from your distributer are good and you have spark going from the distributer to the coil
