kartman
- Apr 28, 2009
- 108
i have no idea what happened, or why it happened. i was cruising around and my 79 merc 80 started to stumble, so i shut it down and checked the fuel. tank 1 was about empty, so i switched tanks to the full one. shortly after, it started running really rough, so i stopped it again and it shot steam out the tattle tale hole, and could find nothing wrong, it didnt get hot and everything looked good. so i started it up again and it had NO POWER. it started knocking for about 2 sec, then it stopped so i kept cruising. but it still had no power and would die if it was anywhere close to idle. at wot i was cruising about 14 just bairly on plane. i finally made it to the ramp, pulled out and got home. i pulled out all 4 plugs and i have no compression in cylinder 1, all the others seem fine. am i screwed? or can i rebuild for a fair price?? i have good mechanical skills for the most part, rebuilt auto engines, built cars but have no ideas about 2 strokes other than theary. any hints, ideas? im so depressed right now, my boat is my only release from the stresses of reality.
