50 horse evinrude not idling
have just returned from a fishing trip, my motor performed great at high speeds, performed good at trolling speed but when i tried to go to neutral and idle the motor stalled. in order to start it up again i had to use warm up lever to give it enough fuel/ throttle.also rpm no longer high enough when lever is full and when returning lever to off position control cable does not push throttle arm back to low idle position and timer base also does not returna ( TIMING ISSUE) PLEASE HELP!!!!
