Early Johnson/Evinrude V-4/V-6 inspection questions
Other than compression check and listening to the motor run what else should I look for when purchasing an older outboard like this? One of the boats I am looking at has a Johnson 200hp and the price of the boat/ motor seems too good to be true, but as usual the owner claims everything works "perfectly". Also, should I expect the owner to let me run a compression check? It sure is an easy procedure on these old outboards, but it can take some time.
