  #1
Old June 16th, 2009, 04:59 PM
tequila dawn tequila dawn is offline
Default 1978 80hp Mariner Running Issues
Hello folks, first time poster that needs help.
I have an 1978 80hp Mariner with some running issues that I need help with. The motor cold starts easily but then begins to develope issues. Around 1200-1500rpm the motor bogs down and wont go above this point for a minute or so then, without throttle input, starts to climb and THEN I can add throttle without issue all the way to WOT. The motor will run all day long at WOT but as soon as I start backing down, starting around 2500rpm, the motor begins to load up and eventually stalls out. At this point the motor will take several minutes to start back up and once it does it will not go above 1500 rpm.
I have a mechanic checking the carbs as we speak but so far no issues not even buildup in them One thing he did note was rust in the number 4 cyclinder (lowest one from top to bottom). He thinks this could be the issue. I want second opinions as far as the running issues.
A second question of sorts what would cause water to enter the lower cyclinder only? All others show clean burn spark plugs and inspection with a scope shows clean cylinders. FYI the water seperator is brand new and was put on at the same time the plugs were replaced last season.
I love this motor and am now at a crossroads as far as repairing or replacing. Any help would be greatly appreciated.
Thank You In Advance,
Regards,
Tequila Dawn
  #2
Old June 17th, 2009, 02:12 PM
Default Re: 1978 80hp Mariner Running Issues
bump
__________________
1976 Grady White Duke 175 w/ 80hp Mariner
"Tequila Dawn"
  #3
Old June 17th, 2009, 02:33 PM
Home Cookin' Home Cookin' is offline
Master Chief Petty Officer
let us know what the mechanic says.
__________________
A man of constant boat tinkering.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
What is the trick for getting lower unit off 1978 80hp Mariner jhoelting Mercury & Mariner Outboards 11 June 15th, 2009 10:58 AM
1978 80hp mariner 4 cylinder biggie Mercury & Mariner Outboards 10 February 24th, 2007 11:49 PM
1978 80hp mariner biggie Mercury & Mariner Outboards 2 January 20th, 2007 06:39 PM
Another 1978 80hp mariner question Boo Mercury & Mariner Outboards 2 December 3rd, 2005 06:14 PM
TRIGGER WIRING 1978 80HP MARINER DWF Mercury & Mariner Outboards 3 March 26th, 2005 05:53 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
