  #1
Old June 16th, 2009, 02:08 PM
JHWERL JHWERL is offline
Default Aluminum painting prep
I have a '96 crestliner pro v 1800 I want to paint. The previous owner did a lot of marsh fishing for spec's. The gunnels and the console are showing signs of what looks like sun and salt corrosion. The sides show normal wear and the bottom is fine. Has anyone blasted an alum. boat with soda prior to painting? It seems like it would be a lot easier than hand sanding.
Thanks for any help!
  #2
Old June 16th, 2009, 02:31 PM
Rickairmedic's Avatar
Rickairmedic Rickairmedic is offline
Send a message via MSN to Rickairmedic
Default Re: Aluminum painting prep
Soda Blasting is fine on an aluminum hull walnut shells also work well .
Rick
  #3
Old June 16th, 2009, 03:59 PM
Bob_VT's Avatar
Bob_VT Bob_VT is offline
After you blast it (stay away from sand or black beauty)treat the hull with alodine or vinigar and water to pickle the metal, add a zinc chromate primer and paint.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
  #4
Old June 16th, 2009, 05:36 PM
sschefer sschefer is offline
Soda Ash (Baking Soda) blasting is the environmentally correct blasting method from what we are being told today.
BUT, if the boat has the factory paint on it, then you can save a lot of work and money by just cleaning it up with 220 sand paper and prime only the bare metal spots. The underlying paint, once scuffed will provide better adheasion than you are likely to achieve in a non professional environment. You do need to check for compatability issues.
Also, every paint manufacturer has their own recommendations as for prep. Some of it is very intesive and others fairly simple. It seems the more expensive the product the more intense the prep. Notice that I said more expensive but not necessarily better.
Bob likes the vinegar and water routine, I like a acid based prime wash like Interlux Viny-Lux. Both methods have their place and work well.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Prep for painting a outboard cparkerc Boat Restoration and Building 10 May 25th, 2009 12:32 AM
Painting Prep maxumlemon Boat Restoration and Building 2 March 16th, 2009 12:40 PM
any advice on topside painting prep? evinice66 Boat Restoration and Building 1 July 7th, 2008 08:03 AM
Trailer prep for painting delta247 Trailers and Towing 3 March 16th, 2005 11:49 AM
Aluminum Paint Prep Jerryda96 Johnson & Evinrude Outboards 1 February 9th, 2003 08:01 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
