Good evening everyone,
I have a question on my 70 horsepower, 1983, model J70ELCTE Johnson outboard. My question is, is I was running my 20' Pontoon boat around pulling a tuber and had 6 people and gear such as a cooler, food, towels, etc. Anyway, I noticed when I first crank it up that a good flow of water comes out the two exhaust relief holes just under the cowling like it is running wide open but it isn't and it pees fine becuase I saw it peeing fine and I just replaced the water pump impeller about a month ago and yesterday was the first day I took it out to the lake. Now, after I pulled tubers and went to the beach to have lunch I took the engine cover off immediatley to see by hand how warm the engine got and it was pretty cool actually cool as a cucumber and slightly, ever so slightly warm around the spark plugs. I did not ever replace the thermostat since I have owned the outbaord and was wondering if the thermostat is maybe stuck open allowing water to circulate and have good water flow out of the two exhaust relief holes out the back of the motor on initial startup and continually there after. Last year, 2008, I rebuilt the carbs myself and got a mechanic to do a lync and sync for me. Is this normal and It doesn't idle as good as I would like it to also. It cuts out on me and I have to raise the warm up lever and then go with it. Do you think the thermostat maybe causing the motor not to warm up to normal temp could cause it to run like it is cold natured and causing it to shut off on me when I give it throttle?
