  #1
Old June 16th, 2009, 09:08 AM
BIB1132 BIB1132 is offline
Default 15hp Evinrude lower unit leak
I have a lower end oil leak having trouble fixing on my 1978 15hp Evinrude.
I have replaced the back to back shaft seals and the oring on the Gearcase assembly. I still have oil coming out of the prop. I have even used a blue gasket seal along the oring for a tight seal as it seemed loose. There is still water getting into the oil (milky) and around the Gearcase Oring you can see heavy oil residue. Is it possible there is a leak at the water pump or another seal that would cause enough internal pressure to push oil/water through the oring even with a good seal? Any help would be appreciated, getting tired of redoing the seals.
  #2
Old June 16th, 2009, 10:20 AM
Vic.S's Avatar
Vic.S Vic.S is online now
Default Re: 15hp Evinrude lower unit leak
Oil Leaking from behind the prop is most likely coming from the prop shaft seals or the bearing carrier O ring Other places that could be leaking are the vertical drive shaft seals below the water pump or even the seal or bushing O ring on the shift rod.
THIS DIAGRAM shows them all
# 2 the prop shaft seals, #7 the bearing carrier O ring, #24 the drive-shaft seals, #25 and 27 are the O ring and seal on the shift rod.
A pressure test should identify the source of the leak.
Don't forget that the fill and level plug washers should not be reused as they can be a source of water ingress.
Don't confuse partly burnt oil from the fuel with gearcase oil. Oil from the fuel leaking from around the prop is normal
See the item "Oil leaking from the lower unit" on the engine FAQs board, top item in the Repair and Maintenance index above
__________________
If it aint broke dont fix it!
If all else fails read the manual
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
72 evinrude lower unit leak jaybirdbadger Johnson & Evinrude Outboards 7 July 13th, 2008 02:59 PM
Lower unit leak on 8 hp Evinrude??? Goosey Johnson & Evinrude Outboards 1 May 7th, 2008 12:07 AM
Lower unit oil leak - 15hp Mariner bostonpilot Mercury & Mariner Outboards 5 November 29th, 2007 02:03 PM
evinrude lower unit (leak) shipwreck Johnson & Evinrude Outboards 1 June 25th, 2007 09:59 PM
80's 15hp evinrude lower unit oil BIGKASH Johnson & Evinrude Outboards 3 June 8th, 2003 07:32 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
