I'm wrestling with an RD-19E big twin that has the old style OMC fuel pump, fed by a pulse hose from the bypass cover around the plugs and to the pump on the starboard side. I've cleaned and reset the carb twice. Got it running by rope starting it this morning and it kept flooding...I've checked the carb float and seat and they work when the carb is off the motor. Weird part is if I clamp off the gas line and let it run off what's in the bowl, it settles down and runs good..good enough that I could set the high- and low-speed needles. Unclamp the gas line and it floods and dies very quickly. Can these old fuel pumps over-run the carb/engine if something is wrong inside...like a bad diaphragm?
