72 winner Outboard damaged transom
Russ Preves
Hi...
I noticed leaking after launching...and saw cracks in the gelcoat by the engine mounts...most likely the engine bounced while trailering....
was thinking of adding/epoxying a 1/2 aluminim plate across the ouside as a fix?
here's pics w/motor removed
Any thoughts?
Thanks,
Russ
Bob_VT
Re: 72 winner Outboard damaged transom
That does not qualify even as a temporary fix. If something goes (i.e. the transom) it will take that plate with it.
Russ Preves
Thanks for your reply....
I was thinking about having this plate across the entire back of the boat...bolted through...but this may be beyond my expertise...how can i determine the extent of the damage?
jonesg
Hi...
I had the same problem, the transom is rotted to pulp, the outboard bolts are compressing the pulp . I chainsawed mine out and poured a seacast transom, you might opt to replace with plywood,
Next thing to check is the stringers, drill a test hole into them and examine the wood chips, very often they go hand in hand with the transom.
my boat came with the temp fix already installed, it was quite well done with thru bolts or threaded stainless shafts 24 inches long which bolted to a cross member in the bilge, everything was braced with alum angle brackets.
The splashwell still cracked!
I used an elec chainsaw, really rips that old wood out quick.
I just glassed the splashwell back in today, woohoo!
I left the reinforcement plate on the transom, less area to sand and paint.
http://s261.photobucket.com/albums/ii67/jonesg_photos/my boat/
