  #1
Old June 15th, 2009, 11:39 AM
pipes0000 pipes0000 is offline
Question best prop for a 14' toon w/40hp rude
I re-powered my 14' Pontoon with a 1986 40 hp Evinrude vro and need some advice on prop choice,It has a 11 3/4 x 17 on it,will this be OK,,, or should I go with something else,,,I have not had it in the water with this motor so I have no Idea on performance.Thanks
  #2
Old June 15th, 2009, 12:15 PM
lmuss53 lmuss53 is offline
Default Re: best prop for a 14' toon w/40hp rude
If you are not loaded real heavy that prop might be OK.
You have to prop the boat so the motor runs in the recommended RPM range at Wide Open Throttle. If the RPM's are high at WOT you need more pitch to the prop. If the RPM's are low you need less pitch. Do not run that motor for long at all outside of that range with the throttle all the way open, bad things will happen. Check on your motor, but I think your 40 is the same as my 50 at 5000-5500 for the recommended WOT operating RPM's. There is a plate on the transom on the s'board side of the motor that shows the rpm range.
I have a 50 Evinrude on my 20 footer that I load real heavy, I ended up with an 11 p prop to get the RPM's in the recommended range. If you need a tach look at Tinytachs.
  #3
Old June 16th, 2009, 10:45 PM
mrdude mrdude is offline
the prop should be around 13p for that motor and boat... thats where i'd start... sell or trade the 17p. wont work.
  #4
Old June 17th, 2009, 10:54 AM
Rancherlee Rancherlee is offline
17 pitch on that motor is designed for a boat that will run 30+mph, A 15 pitch is for around a 26-32mph boat. I know they make a 13x11 pontoon style prop for the 40/50/55/60hp twin cylinder engines but with a small 14 foot pontoon that might be Too low of pitch.
  #5
Old June 17th, 2009, 10:58 PM
http://www.turningpointpropellers.com/
Try using the prop tool I attached to help select a prop for your boat. The 17 is probably going to be too much prop for you, but I would try it and see. I have a 13 that will fit your motor if you are interested in it PM me.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Prop size for 40hp rude on 18' pontoon?? tawd77 Prop Questions and Topics 10 April 27th, 2009 02:01 AM
Best prop for a 24' Toon and Evinrude 115 rivrhnd Prop Questions and Topics 3 June 14th, 2008 12:52 PM
Prop Swap? 14 x 19 for a 14 x 15 Volvo Penta Wimperdink Boat Topics and Questions (not engine topics) 10 September 2nd, 2005 05:20 AM
14' toon or any toons one more cast Boat Topics and Questions (not engine topics) 6 February 15th, 2005 03:15 AM
how to pick the right prop?15+17 or 14+19 ,14+21 ss or coped? MR GIBBS Johnson & Evinrude Outboards 3 July 27th, 2002 09:55 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
