  #1
Old June 14th, 2009, 09:54 PM
docoakley01 docoakley01 is offline
Default Correct prop on used boat?
Hello
I have a 99 182 Crownline with a 190 hp 4.3 Merc Alpha one outdrive. The boat came to me with an aluminum 3 blade 14 inch 23 pitch prop which I promptly gouged out on my maiden voyage. The prop has a bronze splined insert, if that helps with the style. I have been reading up on props a bit, and a 23 pitch on a V6 might not be the correct prop for this boat? I find WOT to be about 5200 RPM, but can't really provide a top speed as I did not run it that high prior to my problems. I need a new prop (or at least a couple of used ones at this rate) but don't want to replace it with the same if it was not correct to begin with. I have my transom ID, etc if it might help.
Thanks for any advice you can give.
  #2
Old June 14th, 2009, 10:20 PM
junior1113's Avatar
junior1113 junior1113 is offline
Default Re: Correct prop on used boat?
is that your wide open throttle rpms with boat in water and in forward. or did u rev it out of water which im thinking, your wide open throttle rpm should be 4400-4800 this is running in the water not on hose. if 5200 is what your getting then u need a 25 at least which is highly unlikely
  #3
Old June 14th, 2009, 10:32 PM
Hi there
That was in the water, but to be honest the TAC did not want to stay there long, it seemed to be most at home around 4800 RPM, it could rev over 5000 but I don't think I would want to hold it there for too long.
Thanks
  #4
Old June 14th, 2009, 10:56 PM
junior1113's Avatar
i swear by 4 blade props since i got one. id put an aggesive 22p 4 on it. better hole shots, mid range speed, slower plane speeds, better gas bill, and holds good in rougher waters.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
prop selection for the slightly used boat sima Prop Questions and Topics 3 September 21st, 2008 09:16 AM
Correct prop for my boat? Dante04SRT Prop Questions and Topics 1 September 4th, 2008 11:36 PM
Finding correct Prop for a Pontoon boat with 70 horsepower Johnson outboard? Big Bubba Prop Questions and Topics 5 May 24th, 2008 09:16 PM
Proper Prop on used boat WanabeBoater Prop Questions and Topics 11 August 17th, 2006 12:51 AM
Used boat new to me with banged up prop DrinkingEmu Prop Questions and Topics 11 June 15th, 2006 08:09 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
