Help! My husband drained the oil from the bottom plug of the tilt and trim because it had some water in it. It worked b4 he did this. It would raise the motor but the motor would vibrate - going down was fine. Had replaced motor of the pump last fall and put in storage -had a dead short in it. Now, after draining the oil, the pump runs, it will not raise the motor - doesn't seem to be any pressure in the hydraulic cylinder. What did he do wrong? Can he fix it or are we looking at repair bill?
