  #1
Old June 14th, 2009, 06:36 PM
Jeremy90bay's Avatar
Jeremy90bay Jeremy90bay is offline
Default Rear drain plug
My boat has been sitting for awhile with the rear drain plug out. it looks like there might be stuff in it. is t safe to shoot water up the hole to try to clean it out?
  #2
Old June 14th, 2009, 06:40 PM
rjlipscomb's Avatar
rjlipscomb rjlipscomb is offline
Default Re: Rear drain plug
Yes, but instead you might want to use a clothes hanger, put a small bend on the end and gently try to pull out the obstructing material (only stick the wire in a couple of inches). Then rinse water down from inside the bilge to clear out the remaining. Otherwise, you'll blow in just to have in block the drain hole again.
__________________
RJLipscomb
2005 Glastron GX-255
Volvo 5.7 Gi-E w/ DP-SM
  #3
Old June 14th, 2009, 06:45 PM
Thank you. I have a capri 1700. would the best place to blow it out be from the front of the batt. compartment. it is in the bow of the boat.
  #4
Old June 14th, 2009, 07:24 PM
redone4x4's Avatar
redone4x4 redone4x4 is offline
Send a message via Yahoo to redone4x4
start at the bow or ski locker, and use a coat hanger and the hose. try a combination of the two, until water flows into the engine compartment or the back of the boat freely. I have had to do this to mine a couple of times because of pine needles n stuff getting down in there. Put the hose nozzle directly over the hole and blast the water thru until it is flowing freely, use the coat hanger, repeat. I got all kinds of crap out of mine that way. then work it all out the drain plug hole with the hanger at the end.
__________________
Samuel Adams. Always A Good Decision.
1987 5.0 OMC capri 1950CX bowrider, 3 bow 6 ft. Westland bimini
  #5
Old June 14th, 2009, 08:19 PM
Thank you for your input. I will have to do this on the next nice day we have.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Which drain plug goes where? vanceboroguy Johnson & Evinrude Outboards 2 April 22nd, 2009 07:11 PM
RDSL-22 Shift Plug (Oops not drain plug) jrpeterson75 Johnson & Evinrude Outboards 11 September 29th, 2008 12:41 PM
Front drain fighting the rear drain? ThePostMan Boat Topics and Questions (not engine topics) 9 June 21st, 2008 09:51 PM
my ticking timebomb (rear floor drain leak in deck) jlawrence4220 Boat Restoration and Building 3 November 13th, 2006 03:10 PM
OMC drive fill plug and drain plug> vonway Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 19 July 27th, 2005 03:06 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
