1973 Evinrude 25 hp starter solenoid
Ok guys, I have the solenoild, a total of 5 wires off of it. Hot wire to battery, plus a hot wire to the push start button. Hot wire on other side going to the starter. Small terminal on top has ground wire on it. Small terminal on the other side has a wire going to some type of switch connected to the shift lever, keeping it from starting while in gear, with a wire going from that switch to the start button.
When I push the button, nothing. Once in a great while it will click the solenoid. Once in even a greater while it will start the engine. Good battery, had it load tested and is fully charged. All connections are cleaned, cables good. Any suggestions on what to do now? I had put a Ford solenoid on it, no luck, replaced it with the original solenoid
Thanks
Reason: replaced "battery" with "starter"
