whalerbeliever
- Jul 12, 2008
- 26
Got it back out after last year to test out, (always drain my fuel after each use) and was just making a grinding noise and only turning once or so. The battery had been sitting after charging a week or so earlier, so I figured on a weak battery. Recharged it and tried again. Started up perfectly a couple of times, and then all of the sudden all I could get was a little click from solenoid I guess. I cleaned the connections, so I'm wondering would the solenoid click if it was bad? Earlier during that first test, I did notice the starter smoking a bit and getting hot. How do I determine if it's the solenoid or the starter?
Thanks for any advice!
