robanderson
- May 21, 2009
- 2
I changed the carburetor fuel filter on my mercruiser 140hp engine. Now fuel is leaking from the inlet connection when the engine is running. It is leaking at the connection where the black metal fuel line connects into a copper nut which is screwed into the carburetor. I know the leak is not were the copper nut connects to the carburetor, because when I squeeze a towel around the metal black line the leak stops. I?ve made sure the metal line has a tight connection to the nut, but it still leaks. Should there be a gasket of some type between the black line and the nut, right not there is not.
I would appreciate any feed back I can get on this.
