  #1
Old June 13th, 2009, 06:49 PM
AquaBum AquaBum is offline
Unhappy 1995 Twilight Cruiser Stalling Problem....
I have a 1995 baja 21 ' boat with a 5.7 mercruiser. when the boat runs good it runs great, however that doesnt happen all that often. Today after riding at high speed for a awhile and the boat is warmed up I entered 5mph zone and after a low idle for a couple of minutes an attempt to shift into neutral the boat stalled. Numerous attempts to restart would not work until after the tenth try,at which point it started but ran terrible idling high and low and attempts to shift between gears was difficult .this scenario happens allmost every time I take the boat out. Ive brought the boat to a mechanic but everytime he starts it it runs fine. I am at my wits end, any ideas. Also if I go tomorow and start it up it probably will run fine until I get to the same scenario that I discribed above. Thanks
  #2
Old August 20th, 2009, 10:59 PM
NHGuy NHGuy is offline
Default Re: 1995 Twilight Cruiser Stalling Problem....
You may have more than one thing going on. The stalling sounds like a shift interrupter issue. If you are mechanically inclined you can adjust the shift yourself.
The poor hot restarts sound something like fuel, carburetor, or possibly timing (distributor).
Is it injected or carbed? What I am about to say is for carbureted engines.
Put the throttle control in it's start position when you go for the restart so you can rev it a bit when it starts. Maybe even give a little squirt of fuel before you crank. If the throttle is just a touch above idle that may help it start a little better when hot. Just don't over rev it when it does catch.
If the gauge shows too high a temp while idling in through your slow-go zone you ought to put the trans in neutral once in a while and bring the RPMs up, this will lower your engine temp if your engine is any thing like my 89 5.7 Mercruiser.
My shift interrupt causes my engine to stumble when I am docking sometimes, it happens when I go straight from reverse to forward. My shifter isn't perfectly adjusted and that's one of its' imperfections.
Why not get your mechanic to drive the boat like a 5 MPH zone after it is warm. He can experience the problem firsthand this way.
__________________
1989 Baja Sunsport 196, Mercruiser 5.7 liter, 260 HP.
Moultonborough Neck, Lake Winnipesaukee, NH
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1995 Evinrude 200hp / Idle Stalling when Warm ericfebs Johnson & Evinrude Outboards 7 October 20th, 2008 06:09 PM
Gasoline Twilight Zone!!!! SoulWinner Dockside Chat 11 October 12th, 2004 01:38 AM
1995 Merc OB stalling at low speed telemorgan Mercury & Mariner Outboards 4 May 3rd, 2004 03:05 AM
1995 Johnson OceanRunner 200 Stalling jonjar2 Johnson & Evinrude Outboards 8 November 27th, 2003 04:53 AM
At werk now, in the twilight zone. 12Footer Dockside Chat 11 April 18th, 2003 07:36 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
