  #1
Old June 13th, 2009, 05:56 PM
grob705 grob705 is offline
Send a message via MSN to grob705
Question push button electric start on 1973 Evinrude 25hp
I have a 25 hp electric push button (mounted on side of engine housing). Good battery, but will not start when I push the button. Will crank and run when I use the pull start.
1, Can I use a Ford solenoid on this motor (4 terminal)
2. Can't jump the solenoid, completly dead. I did change the battery, new one fully charged hooked up to it.
3. When I put a hot wire to the starter side and the small terminal the starter kicks in.
4. Is there a safety switch or rectifier that might be bad?
5. Where can I get an OEM manual for this motor?
Thanks,
George
  #2
Old June 13th, 2009, 06:38 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: push button electric start on 1973 Evinrude 25hp
OEM manual, outboardbooks.com or try ebay, especailly searayman13.
use a evinrude solenoid, ford could blow electronics. http://www.iboats.com/mall/partfinde...****=264683519
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old June 13th, 2009, 06:45 PM
F_R F_R is offline
Thanks,
George
1. Yes, but don't make any connection to the small "I" terminal. The Ford is grounded internally and the I terminal is for a different purpose.
2 & 3. I don't understand your tests. If you jump between the battery + terminal and the small, ungrounded solenoid post, the solenoid should activate and the starter run. If it does that, the solenoid is not bad.
4. No.
5. www.outboardbooks.com but it probably won't cover the electric starter because it was an accessory. Maybe they will have the accessory sheets--ask them.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1973 Johnson 25 Hp Push button Ignition Installation Kaffer62 Johnson & Evinrude Outboards 11 April 1st, 2009 10:09 PM
FROM KEY START TO PUSH BUTTON!! Evinrude yelladog Johnson & Evinrude Outboards 15 August 30th, 2006 11:16 PM
1973 50hp Evinrude electric shift won't start...Help! 99silverado Johnson & Evinrude Outboards 35 December 15th, 2005 12:46 PM
1974 evinrude 15 Hp Push Button Start Baitcaster Johnson & Evinrude Outboards 2 January 26th, 2005 12:48 PM
Help wiring solenoid to electric start push button and battery Illinois Boat Topics and Questions (not engine topics) 3 March 30th, 2003 07:47 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
