Drifting out in front of lake house and when i started and placed it in reverse started to back up and hit something. Turns out a petro line runs into lake and there are concrete bags under the water. I pulled boat out pulled prop and was able to get it fixed.
When pulling prop I notice smell of gear oil after I put prop back on I lowered motor, gear oil start leaking out of bottom at steady rate Motor is a inboard with OMC Cobra - is there a chance a busted a seal in there? Also noticed when I spin prop it seems to be a little warped and noisy. Pulled top plug and gear oil seeped out so I know it was full. How concerned should I be?
