  #1
Old June 13th, 2009, 09:59 AM
havasu2009 havasu2009 is offline
Default no trim
1990 25.5 sx ,I just bought this boat and drive was down,trim wont come up
  #2
Old June 13th, 2009, 03:58 PM
TilliamWe TilliamWe is offline
Default Re: no trim
Are you using the "trailer" button or the "trim" button?
  #3
Old June 13th, 2009, 04:22 PM
Default Re: no trim
I hear the relay on the trim down, but nothing on trim up,no action when using trailer up
  #4
Old June 13th, 2009, 05:45 PM
Default Re: no trim
Time to check power at the pump. Sounds like an electrical issue. Sounds like you may have a few of them?!
  #5
Old June 22nd, 2009, 08:57 AM
Default Re: no trim
found loose down trim connection,it works need to replace up relay,also replaced water pump and t-stat temp stays at 180
  #6
Old June 24th, 2009, 12:26 PM
Default Re: no trim
Good job. If you are using the boat in freshwater exclusively (I know Lake Havasu is fresh water), then 180 degree thermostat is fine.
In the olden days (70's and 80's) Mercruiser used to put 120 degree stats in! They did that, cause if run in saltwater, the lower engine temp would help keep the salt from crystallizing as bad inside the motor. If you ran in fresh only, you could put in a 140 degree. Later, Mercruiser changed to 140degrees standard, with 160 being the optional. However, as you know, in a GM truck, a 7.4 (454) would have a 195 degree stat. So 180 is just fine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Tilt Trim 1977 115hp Mercury trim motor spins only 115merc Mercury & Mariner Outboards 5 June 26th, 2007 11:36 AM
Replacing Manual Trim with CMC PT-130 Power Trim ostank1948 Johnson & Evinrude Outboards 0 September 28th, 2006 11:42 AM
89 150 Merc trim problems after trim-motor rebuild ahsah Mercury & Mariner Outboards 0 July 2nd, 2006 01:23 AM
Questions about repalcing trim limit and trim sender wires on alpha I tkincaid86 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 July 31st, 2004 07:17 PM
120 Force Trim limit switch and Quicksilver trim rocker FishJC Force & Chrysler Outboards 2 April 5th, 2004 05:07 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
