javlin1989
- Apr 16, 2009
- 5
Ok here is my problem i have a 1990 200 evinrude. I have a lean sneeze on one cylinder at idle. power head has less than 2 hours on it Compression on all 6 cylinders is 85 psi i have disasembled and cleaned all 6 carbs, replaced gaskets behind butterfly valves, sinked all butterfly valves they are all closed, new fuel filters, new plug. at idle it sneezes on that one cyclinder. If i take that plug wire off while idleing it stops sneeezing and idles fine. Carbs are clean clean clean. I ran a can of OMC engine tuner through it via shrader valve no change. i have checked all fuel lines I can not find a leak I am pulling my hair out trying to find cause anyone have any advice. also replace primer can seals and new shrader valve assembly.
