assuming carb problems on 1999 115hp yamaha 2 stroke
hey guys,
well guys I have been wrestling with a problem for the past 3-5 outings. after draining tank and replacing fuel. checking fuel pump. and changing the water/fuel separator 3 times and taking all fuel to carbs, I am hoping I can rule out water in the lines. Recently I have been having an issue with the motor losing rpms and sometimes won't get above 1700. if i bump the choke it will slowly rise or if i reach back and use the manual choke about half way out it will pick back up and get up to speed. sometimes this doesn't work and i have to put back to ramps at 6mph. sometimes at low RPMs i get a little sneeze which is scaring me (was told that this was a sign of a lean mixture)
anyone know of or had these issues before? Am I just doomed to paying the 750-1100 dollars (rough estimate from local shop)?
I am tearing into the carbs with hopes of dirt,sludge, or a note saying this is the problem. I am at my wits end if this doesn't fix it I might be done :-)
