Re: 89-90 Force 120 engine doesn't shut off
First off, please do not pull the fuel line to kill the motor. It will run the carbs out of gas, usually the top one first, and create a lean and non lubricated condition = will damage motor !
Instead, place your hands over the carbs to starve the engine of air.
Be careful of the spinning flywheel !!
Is this motor new to you?
Or have you had it a while and this is just a new problem?
Is there any noticeable change in the way the engine runs after you turn off the switch?
By turning the key off, or flipping the kill switch, you should be grounding the ignition system, thus killing the engine.
On the ignition switch terminals:
M - white or black/yellow stripe wire
M - blue or blue/black stripe wire
I - Red/blue stripe
S -Yellow or yellow/red stripe
C - green or yellow/black stripe
B - Red
On the terminal strip on the side of the engine:
The 2 black/yellow striped wires from the cd modules, should connect to the white or Black/yellow wires in the harness.
THe blue or blue/black stripe wire in the harness, should go to the terminal strip, then connect to a motor ground. This wire must ground in order to kill the engine with either the ignition switch or the kill switch. I suspect this is where the problem may be.
