Hello all, I am new to the forum and boating. I have been fixing up an old 1973 signa with a 73 evinrude 135 hp. I took it in to a mechanic to check out what needed work. After pulling out the spark plugs he found that in the #1 cylinder on the right side the spark plug was melted or burnt out. He stated the others looked ok, but the #1 cylinder was going to need a rebuild. He gave me an estimate of $ 3,000 dollars if thier shop does it. What are the best procedures to fix this? Where can I find affordable parts? Are any other makes or models compatible with this motor? Does the cylinder need to be bored out? Is there a good service manual to take you through the steps of repairing this problem?
The mechanic also stated the carbs need to be cleaned or rebuilt. Where is the best place to order parts for a carb rebuild kit?
