  #1
Old June 12th, 2009, 07:24 PM
Bob1944 Bob1944 is offline
Send a message via Yahoo to Bob1944
Angry 1963 Evinrude 40 HP Electric Shift water pumping problem
I changed the impeller but all I get it a little spray out of the hole just under the engine head. Should there be more. I would think it would come out like from a garden hose eh?
Or does it get pumped out from the exhaust above the prop underwater?
  #2
Old June 12th, 2009, 07:39 PM
F_R F_R is offline
Default Re: 1963 Evinrude 40 HP Electric Shift water pumping problem
It is NOT a garden hose!! That motor has a thermostat controlled, recirculating cooling system. When the thermostat is closed, a bit of spray comes out the back to tell you that it is working, but most of the water goes back to the water pump for recirculaton till the engine temperature is warm enough to open the thermostat. When the 'stat opens, there will be a heavier spray, but still not a garden hose. With an open 'stat, most of the water goes out with the underwater exhaust.
You should be aware that the 'stat constantly monitors the temperature and opens and closes as required to maintain a steady temp. So, the spray varies all the time, and is closed more than it is open at idle speeds.
Actually, this is exactly how a car's cooling system works, except they use a radiator instead of a lake for the cool water supply. A car's 'stat also constantly monitors the system and opens and closes as required to maintain proper temp.
  #3
Old June 13th, 2009, 09:47 AM
Well I will be a blue nosed gopher. Pretty technical for a 63. Thanks for the excellent answer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1963 Evinrude 40 HP Electric Shift Bob1944 Johnson & Evinrude Outboards 3 May 4th, 2009 09:38 AM
1963 Evinrude 40 HP Electric Shift Problem Bob1944 Johnson & Evinrude Outboards 16 April 26th, 2009 08:17 PM
1963 40 hp electric shift freddyray21 Johnson & Evinrude Outboards 4 September 18th, 2008 09:55 PM
1963 40 hp johnson electric shift compression readings terry2626 Johnson & Evinrude Outboards 3 December 14th, 2006 04:34 PM
1963 evinrude 75 horse electric shift Jeffrey M Goldberg Johnson & Evinrude Outboards 3 September 4th, 2003 03:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
