  #1
Old June 12th, 2009, 03:54 PM
BoatGRD BoatGRD is offline
Default Evinrude Ficht Inj Fuel Test Port Problem
We have a 135 hp Evinrude with the Ficht fuel injection system that was manufactured around 2000. The fuel test port blew out of the line because of too much pressure. There was a minor explosion that cracked the fiberglass housing over the motor and a small fire. We were able to extinguish the fire and the dealer repaired the motor according to manufacturer instructions using a new part that eliminated the test port. The problem has reoccured but this time caused another part to fail because of the pressure we have had a second fire but a little less damage. I have heard that this is not an uncommon problem and would like to know if others are aware of similar occurences.
  #2
Old June 13th, 2009, 10:41 PM
seahorse5 seahorse5 is offline
Default Re: Evinrude Ficht Inj Fuel Test Port Problem
If you think the fuel rail pressure is too high, then there may be a problem in the pressure regulator or the cone shaped filter inside the vapor tank is clogged.
It would be best to check the fuel pressure and post it here.
what is the engine model number?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
02 Evinrude Ficht fuel test port problem bros250 Johnson & Evinrude Outboards 1 May 2nd, 2009 02:33 AM
Fuel pressure test port bros250 Johnson & Evinrude Outboards 2 April 27th, 2009 10:29 AM
fuel press test port? zindale Johnson & Evinrude Outboards 2 August 10th, 2006 09:32 PM
2001 Evinrude 115 Ficht fuel problem stingfish Johnson & Evinrude Outboards 6 April 12th, 2006 05:32 PM
Evinrude 115 RAM ficht 2000 fuel problem JACQUES Johnson & Evinrude Outboards 0 June 26th, 2003 02:56 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
