I have a 15 HP Evinrude that I purchased from a older gentleman near Minneapolis MN 1 year ago. Since I have had it I have had to replace the coil and spark plugs. Nothing unexpected.
Today I had my boat out and whenever I reached full throttle my engine would kick out of "forward" gear into neutral. When it was doing this the RPMs were very high. I reached over and pull it back into forward then it was good to go until I reached full throttle again. Then repeat, repeat, etc...
My motor is very cold blooded even in this Minnesota heat (70 degrees is hot right?). The motor has new spark plugs. I think the carb might need to be cleaned. I am a newbie when it comes to outboard motors. I would like to do stuff myself if possible. Is cleaning the carb an easy chore or something for a pro to look at?
And another thing, I observed that the lower unit was bent when I turned the prop by hand. Is this something to worry about or do I need to get a replacement immediately? If I need to change this, is it a troublesome task?
Any help would be appreciated. Thanks again,
Adam
Adam
