Base carb settings on 2003 Tohatsu 40M?
mabbott
Hi Does anyone know what the base carb settings are for a 2003 Tohatsu 40M? Are all three carbs set the same to start?
pvanv
Re: Base carb settings on 2003 Tohatsu 40M?
If this is an M40D, then the short answer is Yes.
Float settings are set the same, and the carbs should be balanced (throttle stops, idle mixtures, and linkages, as with any multi-carb setup on any motor.
mabbott
Thank you....but what are the base settings??? How many turns out?
When taken apart one was at 3/4 another was 1-1/2 and tanother was 2-1/4.
No wonder it ran crappy.
deejaycee_2000
1 & 1/2 full turns outwards from soft stop ........
pvanv
You may want to get a service manual, available from a Tohatsu/Nissan dealer.
mabbott
Thank you for the responses.
TOHATSU GURU
Intial setting is 2 1/4 +- 1/4...Ditto on the manual.
