...the recoil starter self destructed after about fifteen pulls. Fresh gas, fresh pug, clean carb, clean points, good spark, but not much action. A couple of hits , a little smoke, but nothing close to running. Compression felt good. Lots of gas sitting in the carb throat, but the plug was dry when I pulled it and looked, so I am not sure what is going on yet.
So I am out a recoil starter, the spring in it appears to be messed up. Any reason I cannot carefully put an electric drill on the 9/16 (i think) bolt on the top of the magneto to get it started? I would like to figure out If the motor is going to run.
Darn.
Darn.
