Hi found a good deal on a full set of 1986 Black Max Carbs. I have heard that the only difference in the 150 black max and the 135 is the carbs. Not sure if this is true. I would love some input.
It is likely the block port timing is the difference accounting for the HP. The carbs will probably fit. They may not work well, and they will not boost HP.
