  #1
Old June 10th, 2009, 06:41 PM
dezwashere74 dezwashere74 is offline
Default New boat owner - engine knocking
Very new to boating, bought a boat 5 days ago. Today, the motor started knocking. It's a 1992 50hp Johnson. Anyone have any ideas for me?
  #2
Old June 10th, 2009, 06:55 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: New boat owner - engine knocking
(Piston Play Check)
(J. Reeves)
This procedure will tell you if there is any wear or play in the Wrist Pin, Wrist Pin Bearing, or Connecting Rod to Crankshaft area.
Remove the spark plugs. Insert a screwdriver, dowel, punch, or some object of your choice through the s/plug hole and into the cylinder/piston area. Hold the tool lightly against the top of the piston. Turn the flywheel by hand, bringing the piston up to top dead center, then continue turning the flywheel to pull the piston down about a inch..... all the while holding the tool lightly against the piston top.
Now, at the point whereas the piston has been dropped down about a inch, grab the flywheel and hold it firmly. Now, push that tool solidly and firmly against the piston top.
If the piston moves without moving the flywheel, there is a problem (wear, play, clearance, etc) somewhere with the items mention in the first sentence. Be sure to check all of the pistons/cylinders.
  #3
Old June 10th, 2009, 07:57 PM
wiretwister wiretwister is offline
If it is knocking dont run it at all until you find/fix the issue....It is very easy to destroy the engine....please report what you find.
Wire
  #4
Old June 11th, 2009, 08:20 PM
Well, husband took motor completely apart. The camshaft bearing was thrown and a bolt was broken off. Upon further teardown, found a hole created by all that in the casing! Now what? Can I buy the casing from a junkyard? Someone suggested welding the hole but that doesn't seem like a viable solution to me. I'll take any suggestions as I'm thoroughly upset.
  #5
Old June 11th, 2009, 10:45 PM
wilde1j wilde1j is offline
What model motor? (If it's a 2 stroke it doesn't have a cam shaft).
__________________
Jim
  #6
Old June 11th, 2009, 11:15 PM
Joe Reeves's Avatar
I strongly suspect that the cam you mention is actually the crankshaft, and the broken bolt is from the retaining portion of the connecting rod. As such, again I strongly suspect that the crankshaft and that connecting rod (at a minimum) will require replacing. This, coupled with the damaged crankcase (hole in the block) really spells out a non rebuildable powerhead.
Yes the crankcase could have a hole in that aluminum crankcase heli arced (aluminum weld) BUT there may be other unseen damage to the crankcase that will result in wasted money and double work.
I wondering, instead of tearing the engine down which would eliminate any implied warranty, why you would not contact the seller about that knocking problem....... that is if the knocking existed right at the start. At any rate, I understand your frustration and can only suggest that you are able to locate a good used powerhead to replace your damaged one.
  #7
Old June 13th, 2009, 08:19 PM
You're right, it is the crankshaft, I misunderstood him. Considering it's a 1992 motor, there is no warranty. We bought the boat from an individual and did contact him but he said he never had any probs with the motor. I tend to believe since he's a pastor, but you never know. We had the welding done to the hole & a small crack that was discovered & replaced the bearings.
New question: The knocking is gone & motor runs, but it sputters. Think the crankshaft may have gotten warped. Wondering if we have the crankshaft turned if we can use the same pistons & bearings?
  #8
Old June 13th, 2009, 08:45 PM
You can't have the crankshaft "turned" ... bearings (main and rod) are only made in one size. It may be possible (but probably not cost effective, to have it remanufactured (weld material added, then turned down to original specs). A better path would be to find a good, serviceable, used crankshaft.
__________________
Jim
  #9
Old June 13th, 2009, 09:17 PM
jonesg jonesg is online now
Wow you guys work fast !
I agonize over changing sparkplugs for a week.
Anyway, the spluttering could be spark or fuel delivery related.
Or an air leak due to a bad (old) gasket.
Its possible because you never stated what caused the initial failure and its very possible the original problem (dirty carb) is still there.
You should rent your husband out.
  #10
Old June 13th, 2009, 10:07 PM
steelespike steelespike is offline
Just to make that a little clearer.If the carb on a 2 stroke runs a little lean
(Not quite enough gas) The crank etc may not get enough lube.
If the motor seemed to stumble or bog on acceleration and maybe not top out strongly could be running lean.Sometimes if a motor is running lean a little choke will help it respond.An indication you need to solve the problem.
Usually a carb rebuild.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
new here, new boat owner, new project cactusprick Boat Restoration and Building 2 October 9th, 2008 07:24 PM
Need Input on New Boat Purchase... (First Time Boat Owner) TheChad Boat Topics and Questions (not engine topics) 10 June 2nd, 2005 05:22 PM
New owner / smoking engine Nopes Force & Chrysler Outboards 4 May 29th, 2004 09:27 AM
new boat owner - rebuilt engine? chriswisc Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 March 1st, 2004 09:36 AM
new boat owner no clue of age of boat & motor GREGH Johnson & Evinrude Outboards 15 September 8th, 2001 05:41 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
