jd0uglas30
- May 18, 2009
- 5
I recently purchased my first boat and have a newbie question. The drain plug is the screw in type, both the plug and the receptacle/threads appear to be made of plastic or a similar material.
The plug itself is a 1/2" plug, but the head of the plug looks to be pretty chewed up from a pliers or other device. The only thing I can find to replace it with is a brass plug. Will this work? I am somewhat nervous about fitting a brass plug to plastic threads, not sure if this will seal.
