I have 2008 Evinrude E-Tec, 60 HP OBM. I tilt it out of the water when I am not using my boat. I find gas in the transom under the tilted motor after it rains (gas mixed with water). And I also find gas (maybe mixed with rain water) inside the casing under the hood. I checked main gas supply hose and it doesn?t seem to be leaking. Did somebody else see problem like this? Any advice is appreciated. Thanks you.
