"ole faithful" comin outta my valve cvr
chuckd
I recently purchased a very reasonably priced boat, with a problem. The 74 mercruiser ford 351 has water in the oil pan, milky looking & the previous owner said the he winterized it wrong, by just pulling the hoses off the end caps, dumping in some anti freeze and closing the cover, thats it no draining of any kind. He stated that he started the motor, but shut it down when he noticed water coming out of the valve cover oil cap where oil goes & rough running.I have checked the freeze plugs and they seem to be intact, I also found the valve to drain the water from the motor, its a ball valve that has ben plumbed into drain the water out & when i opened it, water did flow. My question is could you advise me as to a starting point of things to check, to find out why water has found its way to the oil pan. Any help would be greatly appreciated. I've worked on several cars, but this is a lil different animal. Thanks to you all!!!!!!!
dan t.
Re: "ole faithful" comin outta my valve cvr
sounds like the block and /or heads are cracked internaly
danond
I hope by "reasonably priced" you mean "free or close to it"!
First, drain the block.
Then do a compression test. That'll get you going in the right direction.
Either way, something is cracked and will need replacing.
Surfdancer
Pull the valve covers and check the top of the head castings. That's where mine failed on the previous owner. The casting cracked around the valve rocker arm studs and water would get into the engine oil big time.
Ayuh,... My guess is, the block Froze,+ Split...
chuckd
ok pulled the valve covers like suggested & surfdancr, it sounds similiar to your experience. the head has a silver dollar sized chunk of it broken out and
along w/ it is the rocker arm and stud. things that make ya go Hmmmm. Im guessn next comes the cylinder comp test, to see if any thing else is damaged? Thanks again to you all for your time and info.
Don S
The compression test isn't going to tell you anything. You have a cracked block under the intake manifold. You can have perfect compression, but still have water in the oil.
Nope,.... Next step is to pull the motor,+ Replace it....
