solar7647
- Apr 23, 2009
- 1,218
I am having an issue with my boat leaning to the left side when at WOT and the trim is all the way down. If I bring the trim up it centers but still leans a little to the left, but with trim down its real bad . Now I have a 1987 four winns sundowner, 3.7l merc, alpha 1 drive. 4 blade prop 14 1/2 inch diameter. Now I know its not the trim tab anode because there is none i have a flat plate, i dont think its prop torque because its leans to the left and the rotation of the prop is to the right. I dont think it is a weight problem becuase the boat is level when standing still or at no wake speeds. There dosent seem to be any issues with the hull ether. Now I do have a hydrofoil, it looks centered, my question is has any one else had this issue using a hydrofoil and it causing this problem? Also would a bent skag cause this, it looks a little off to the left. Or does any one have and suggestions, I am clean out of Ideas!!
Thanks a lot!
Thanks a lot!
