Kicker Motor Size?
mannbc
I have an 18 ft I/o and would like to add kicker motor to it. It would be used to get boat back to slip if I/o motor died, and for trolling only. How does one size the motor, and what is needed to mount it to boat. I would like to be able to control it for steering at front. Also Do I need a outboard with electric start, or can it be started front front. Is there electric start conversions available for pull starts?
Thanks in advance!!
ondarvr
Re: Kicker Motor Size?
Find something in the 8 to 15hp range with a long shaft if possible.
As far as controls, you can get electric start, PT&T, and control eveything from the helm if you want, just costs more.
New you can anything you want, used older motors aren't likely to have PT&T, but you can get electric start and remote controls.
