  #1
Old June 9th, 2009, 02:04 AM
deltaguy deltaguy is offline
Default question for pontoon experts.
i remodeled my pontoon and move a few things around but now the front rides high and the back sits low.. about 75-80% of the back of the boat is underwater..should i move the battery up front?? how far up does it need to go? and for my starting battery what size wire should i use 40hp outboard.
checked the weight of the two battery's and they weigh just over one hundred pounds. they are mounted all the way on the back of the deck and i have a 18 gal gas tank mounted on the back also on opposite side. i will take a pic of it all and post it later.
thanks in advance
  #2
Old June 9th, 2009, 07:54 AM
5150abf's Avatar
5150abf 5150abf is offline
Default Re: question for pontoon experts.
that is a pretty common problem with toons, gas, batteries, motor and tons of furniture ect all in the back 5% of the boat so it rides low in the back.
If you can get a battery up front I would, the start battery needs to stay by the engine though and try to get people to sit towards the front under way but without moving a bunch of stuff around really nothing you can do.
__________________
GO IRISH!!!!
  #3
Old June 9th, 2009, 10:23 AM
is the boat safe to drive like that?? also why cant i move my starting battery up front?cars have baterys in the trunk without a problem. what makes it different for a boat? not trying to be a smart *** just trying to learn here.
  #4
Old June 9th, 2009, 02:52 PM
Silvertip Silvertip is offline
You can leave the battery on the dock (I'm exagerating here of course) as long as the battery cable is long enough and large enough. The farther you get away from the engine the greater the voltage drop. Starters draw high current so the cables you use to reach the new battery location must be at least as large or one size larger than the existing cables. Are you sure the tubes do not have any water in them?
  #5
Old June 11th, 2009, 01:43 AM
k i checked if there was water in the toons.. i think there is a little water in the front cones both sides.. i see some repairs done up front a weld on one side and a patch on the other.. iam almost positive that its water only in the front but i want to confirm that the cones in front are separate from the rest of the toons.. ive heard that it might be three chambers but i want to make sure..
  #6
Old June 11th, 2009, 05:39 AM
5150abf's Avatar
Yes, each section should be seperate.
__________________
GO IRISH!!!!
  #7
Old June 11th, 2009, 08:15 AM
Jeep Man Jeep Man is offline
On my old toon, there are separate chambers, but water ccould drain out through the rear. There seemed to be a small hole between the chambers. If yours is the same, the water could collect in the rear.
__________________
I've fished for half of my life, the rest I just wasted.
  #8
Old June 12th, 2009, 02:09 AM
ok now that i know theirs water in the front cones were can i buy some aluminum bungs with plugs or bolts? think iam gonna weld one on each corner or is there a better solution..the boat is a 1997 suntracker 18ft
  #9
Old June 14th, 2009, 01:35 AM
trooplewis trooplewis is offline
'drooping' pontoons are pretty common. See photo, there is a lot of these on the Colorado River
Not a whole lot you can do about some of them.
Redistributing weight is good, but if yoi do it with the batteries, use #2AWG cable, and if you store them under a seat make sure you use sealed batteries, like a gel battery.
  #10
Old June 16th, 2009, 05:48 PM
chrisg chrisg is offline
From your pic, and looking at the water line on mine, it looks like that is not that much of an issue. Its not sitting that far down. A pair of big inlaws at the front should solve the issue.
__________________
Chris
Gave up on searching for a lake in Iowa!
  #11
Old June 19th, 2009, 03:16 AM
are you serious can the boat operate properly like this?? does not look safe at all.. the waters were iam at are very choppy at times with 3-5ft swells..
  #12
Old June 19th, 2009, 04:01 PM
samm835 samm835 is offline
Send a message via AIM to samm835
No you should NOT operate your toon if its drooping that much. If its drooping that much you have major issues. Anyone who sets out with a toon looking like that is asking for trouble quickly, not only the over pressure your putting on the motor, but the chances of it finally deciding to sink down and possibly hurting your passengers. Also who in the hell would want to climb to the front seat after going to the back...to much work for trying to have a relaxing day on the lake.
  #13
Old June 20th, 2009, 11:48 AM
AZAL AZAL is offline
Talking Re: question for pontoon experts.
[quote=trooplewis;2149643]'drooping' pontoons are pretty common. See photo, there is a lot of these on the Colorado River
What you don't see in this picture is the 10 people sitting in the shade behind the towels and the 6 iced coolers of beer.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
question for the experts freddyray21 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 May 29th, 2007 10:54 PM
Question for oil experts kenimpzoom Non-Boating Technical Topics 5 May 16th, 2006 04:24 AM
Question for Ignitions Experts Friz Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 October 18th, 2005 12:26 AM
Question for all the experts...... KCLOST Mercury & Mariner Outboards 17 September 9th, 2003 08:34 PM
Question for Honda experts cn2bakers2 Honda & Tohatsu/Nissan Outboards 8 August 25th, 2003 06:32 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
