Re: 20 hp merc electric starting problem
The most common starter problems are a low battery and/or poor battery cable connections.
Check the battery voltage, if low, recharge and take it to AutoZone or NAPA and have it Load Tested to be sure that it is in reliable condition.
Lightly sand clean BOTH ends of BOTH battery cables AND the short cable linking the starter to the relay.
