  #1
Old June 8th, 2009, 09:02 PM
pdc0315 pdc0315 is offline
Default 1984 Bayliner Volvo heats up / new boater
I have recently purchased a 1984 Bayliner open bow (Carpi ?) Volvo engine, 270 outdrive. This is my first boat... after replacing the points it runs like a top. Last weekend, first time in the water, it seems to heat up if I run it over 3,000 RPMs. If I keep it around 2,500 or less it will maintain a running temp. I also have a small drip from what I assume is the "raw water" pump.
Is my problem a symptom of an impeller that needs replacing? There is also a shaft and seal kit... is that needed also? I'm not sure how to proceed as I know I have a 270 outdrive but I can't find a serial plate on the engine. Am I to assume this is the AQ125 (A or B?) 4 cylinder Volvo?
Is it likely that the problem is with the circulating pump rather than the raw pump? I'm searching for any tips or information related to this old boat.
  #2
Old June 9th, 2009, 03:37 PM
gcboat gcboat is offline
Default Re: 1984 Bayliner Volvo heats up / new boater
First thing I'd do would be to replace the thermostat. Do keep an eye on the circulating pump though. As far as the complete kit is concerned I'd go ahead and do it. No telling how long the impeller has been in there.
Thermostats are a lot cheaper than pumps or impellerr kits.
__________________
Life may not be the party we hoped for, but while we are here we might as well dance
  #3
Old June 15th, 2009, 04:32 PM
emarkd emarkd is offline
I've also just bought an 84 bayliner capri with a volvo sterndrive setup in it. The plate on my motor is on the port side of the block on the protrusion where the starter mounts. My seawater pump was ok but the two seals where the lines bolt on were shot. I got mine from marinepartsexpress.com for about 4 bucks each. Hope that helps.
  #4
Old June 16th, 2009, 05:45 PM
ThePostMan ThePostMan is offline
You most likely have an AQ125A with a 270 outdrive, standard issue on that particular boat.
Obviously do the cheap stuff, including impeller (you just need the impeller and gasket for this. . .and it should be done every couple years. The thermostat is cheap, but I've never heard of an engine overheating because of a bum thermostat all by itself.
Now, your issue is probably on the outdrive. This setup is notorious for corrosion on the goose-neck "thing" that connects your lower-unit pickup to a rubber hose (kinda the size/shape of a radiator hose) and through the transom. The goose-neck thing might look like it's in perfect shape, but it probably has small pits or cracks inside the hose that you can't see. It will pass water through just fine when it's totally submerged (because it's sucking water through those holes, too). . .but once you're running at speed, the goose-neck is out of the water, it allows some air to pass through, and you get a water/air mixture to your raw water pump.
It's a cheap fix, too. . .replace that neck, its gasket, and the hose while you're in there messing around.
EDIT: Volvo part number 854031
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1984 Volvo Penta I/O Drive lift Broken! (Bayliner) Danwec Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 July 23rd, 2007 07:24 PM
volvo outdrive on bayliner 2655 1984 thuncrft Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 August 9th, 2004 12:38 PM
volvo outdrive on bayliner 2655 1984 thuncrft Boat Topics and Questions (not engine topics) 2 August 9th, 2004 12:38 PM
New boater - 1984 Force 125 ob12 Force & Chrysler Outboards 3 June 19th, 2004 09:09 PM
1984 BAYLINER VOLVO PENTA AQ125A giniustflord Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 March 19th, 2004 07:20 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
