I have a 1997 evinrude 115 v4 90degree carburatuered engine...I seem to be running too rich.....she's running a lil smokey and I seem to be getting a lil to much unspent oils in my exhaust....I am just basically running it at low idle here in my driveway... Could my excessive idleing be causing this? I have a repair manual that covers many years and models so at times it can be a lil vauge with details..... the book says that to run at a proper idle the carb plates should be closed...Is this true?...my carbs have no adjustments they are fixed....by adjusting my cam follower to slightly open the carbs I should be able to lean it out.....Any input on this matter would help.......thanks
