  #1
Old June 8th, 2009, 03:52 PM
jbatzkiel jbatzkiel is offline
Default 86 bayliner capri steering ?
my boat has a rack & pinion steering system, it turns right pretty easily but turning back to the left is difficult, what can be done to correct this? thanks for any advice
  #2
Old June 9th, 2009, 10:06 AM
gcboat gcboat is offline
Default Re: 86 bayliner capri steering ?
Take a look at the position of your trim anode. It should be just left of the center position. If not loosen it and move it there. It might take some playing to get it correct but remember you don't have power steering so it will be a little harder turning to port. Called prop torque.
__________________
Life may not be the party we hoped for, but while we are here we might as well dance
  #3
Old June 9th, 2009, 10:15 AM
it is much more difficult to turn left than right, even out of water, engine not running.
  #4
Old June 9th, 2009, 10:28 AM
My misconception - sorry. Looks like now you can start by looking at binding cables, worn, frayed, etc. Remove the cables from the motor and see if there is any difference in the action of it all. If stll binding then you need a new steering unit or cable replacement. If it is smooth then check the movement of your motor. Don't know what kind of motor you have but there is usually a zerk fitting under the cowling to add grease. It's usually one or the other, unless the boat has been sitting for a while then they both might give you a fit.
Right now it's just trial and error on your part.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
86 Bayliner Capri bowrider fixer upper kmelville2 Bayliner Boats 3 June 7th, 2009 10:22 PM
86 Bayliner capri with 85hp force Steering Wheel off danandsaraht Force & Chrysler Outboards 2 September 27th, 2006 08:56 PM
86 Bayliner Capri BayCapri Bayliner Boats 3 April 20th, 2006 05:56 PM
owner's manual for 86 bayliner capri same as 85 capri? massimofinance Boat Restoration and Building 3 December 5th, 2004 09:35 AM
86 bayliner capri PlaynHooky Boat Topics and Questions (not engine topics) 6 November 9th, 2001 06:33 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
