  #1
Old June 8th, 2009, 08:29 AM
MID FL CAP MID FL CAP is offline
Default broken bolt in t-stat 1990 225 yamaha
Hello,I removed the thermastat,and broke 3 out of four bolts in the process.I was able to heat 2 of them up and the were removed with a great deal of power.The third one would not move ,so I cut it off and drilled it out with a small drill bit,BUT I went to far and went thru the block,I think.The question is ,did I really do a lot off damage by goning to far with the drill dit?Is there a water jacket behind that ,or what,I do'nt know for sure? Could I put a little J B weld in it and then the bolt,with some anti-seize on it then the gasket and call it good,or a nother course of action reqired? Hope some small fix-it or major job? At any rate the t-stats were shot,so I was doing something right by inspecting them before heading for blue water!! THANK YOU for your help in advance!!!Ray.
  #2
Old June 18th, 2009, 10:36 PM
Smile Re: broken bolt in t-stat 1990 225 yamaha
Note To Self And Others.i Used Heavy Force With Vise Gripes,was Able To Take Two Out That Way,with Help From Penertrating Oil.the Other One's: I Hade To Use Heat (a Cutting Tourch) It Helped Alot. The Last One Could Not Get It To Move No Matter What,cut It Off,and Drilled It Out And Then Re-taped It.put All New Bolts Back In It With Some Pipe Dope,new T-stats ,gaskets,everything Working Fine.
  #3
Old June 18th, 2009, 10:49 PM
mcbassin mcbassin is offline
Default Re: broken bolt in t-stat 1990 225 yamaha
You might also note great care should be taken when heating that aluminum, it is very easy to get it too hot fast then things can go bad in a hurry.
  #4
Old June 19th, 2009, 07:29 PM
rodbolt rodbolt is online now
gotta love heat
at 6ft and and amazing 140 pounds I am a special scarecrow, I aint scared of fire.
lots of old saltwater yammies here with 1/4X20 bolts holding the t-stst housing in place though.
but if your careful you can use that cutting tourch to heat it enough the bolt draws the threads right out making a helicoil a snap to install.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1990 Yamaha 225 solenoid consie67 Yamaha & Suzuki Outboards 5 July 20th, 2006 10:12 AM
1990 yamaha 225 jdc946 Mercury & Mariner Outboards 1 November 6th, 2005 05:24 AM
frozen bolt on t-stat cover eluder1 Mercury & Mariner Outboards 4 June 1st, 2005 05:03 PM
yamaha 200 1990 outboard shift rod broken artis Yamaha & Suzuki Outboards 2 October 19th, 2004 05:58 PM
1990 Yamaha 225 2.6l oceanrunner28 Yamaha & Suzuki Outboards 7 June 29th, 2004 02:30 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
